all paddle clutch users
Old Jan 28, 2006 | 08:15 PM
Badman38's Avatar
Badman38
Default all paddle clutch users
after having a new paddle clutch fitted did any of you suffer from clutch slip, and is it true paddle clutches need bedding in due to the cerametallic pads.
Old Jan 28, 2006 | 08:19 PM
addiction's Avatar
addiction
just bolted mine in and off i went. worked a treat from day one,no slip,no judder and a nice pedal to boot
Old Jan 28, 2006 | 08:38 PM
Badman38's Avatar
Badman38
i had no issues at all with my ap paddle work fine from straight out of the box but my helix four paddle slipped badly from day one, then after i done a few miles it started to grip.. now i am having the same problem with my helix six paddle and heavy duty cover and the rolling road shootouts on saturday
Old Jan 29, 2006 | 09:56 AM
Tim's Avatar
Tim
Should be fine out the box but i have heard that the 6 paddles wernt all that sound,but its just what i heard
Old Jan 29, 2006 | 10:23 AM
Hrsturbo's Avatar
Hrsturbo
I gave mine a few hard launches and slipped twice but not bad. Never done it since
Old Jan 29, 2006 | 10:24 AM
T28 RST's Avatar
T28 RST
Ok then
Mine has never slipped and its been in it for 3 years
Old Jan 29, 2006 | 11:05 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I normally go for a complete engine rebuild when I change a clutch so I wouldn't know as I always do a 1000 miles before putting my foot down
My Alcon seems ok though, gets quite a bit of abuse, hard launches too.
Old Jan 29, 2006 | 03:56 PM
rambo11's Avatar
rambo11
my 4 paddle lasted 8 months i had my flywheel skimmed BUT i used a standard pressure plate
Old Jan 29, 2006 | 04:05 PM
Combi_Chris's Avatar
Combi_Chris
im about to have a new clutch fitted , what else should i look into , like for example whats the deal with the flywheel ??
Old Jan 29, 2006 | 04:30 PM
Oranoco's Avatar
Oranoco
My Helix started slipping a bit about a month after it went in then it stopped after about a week and hasn't slipped since
Old Jan 29, 2006 | 07:07 PM
Exeter J's Avatar
Exeter J
My ap 4 paddle slipped only once for about 10miles soon after the rebuild and then it was fine.
Old Jan 29, 2006 | 08:42 PM
Badman38's Avatar
Badman38
have your flywheel skimmed just to make sure it is flat otherwise you could ruin your clutch in no time..
jessie_rs
11
Jun 3, 2019 04:57 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Chas
Sep 21, 2015 08:57 PM
mint_s2
Sep 2, 2015 08:58 AM
mattman1234
15
Aug 14, 2015 10:05 PM
