fuelpump question>all cosworth technicians
Old Jul 20, 2004 | 07:55 PM
cossiemen's Avatar
cossiemen
Whassup
Default fuelpump question>all cosworth technicians
how much bar should a cosworth 2wd fuelpump give??
is it more or less then 5bar??
thanks
Old Jul 20, 2004 | 07:56 PM
GARETH T's Avatar
GARETH T
depends on the boost!
what you trying to do?
Old Jul 20, 2004 | 07:59 PM
Uncle Henry's Avatar
Uncle Henry
pump delivery pressure should be 5 bar minimum as standard
Old Jul 20, 2004 | 08:03 PM
cossiemen's Avatar
cossiemen
Whassup
right, a while ago i've ordered a fuelpump and they delivered the wrong one (was posted onhere before)
I asked for a standard cosworth 2wd one and they delivered me a standard ERST one
so, my car is running on standard bhp and standard boost so can i use the ERST one instead off ordering another one??
cheers
Old Jul 20, 2004 | 08:04 PM
GARETH T's Avatar
GARETH T
pumps create flow not pressure!
Old Jul 20, 2004 | 08:05 PM
GARETH T's Avatar
GARETH T
sorry i do know the flow rates!
Old Jul 20, 2004 | 08:16 PM
cossiemen's Avatar
cossiemen
Whassup
right, gonna ask if its possible too fit a ERST fuelpump on my 2 wd cosworth instead of a cosworth genuine one ?
does it give enough flow as i'm running on standard bhp and standard boost...
cheers
Old Jul 21, 2004 | 01:34 AM
cossiemen's Avatar
cossiemen
Whassup
Old Jul 21, 2004 | 02:32 AM
Stu @ M Developments's Avatar
PassionFords Creator
Pump creates in excess of 10bar if locked down but the reg obviously sees to it that this isnt the case.
As for fuel flow, the RST pump will cope with around 250bhp so you should be just fine.
Old Jul 21, 2004 | 03:11 AM
cossiemen's Avatar
cossiemen
Whassup
thank you very much Stu; you are the men
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
