work this one out??
not a cossie problem but on a N/A 4cyl mini engine, bizarre till we worked it out anyway.
with distributor / coil ignition, starts running on 3 cylinders (felt like a plug lead had fallen off). to try and indentify the faulty cylinder (or plug) we take each lead off in turn.
the engine is idling at the time.
removing #1 causes the engine to slow till almost stalled.
removing #2 increases engine speed.
removing #3 has no effect on engine speed.
removing #4 has no effect on engine speed.
answer later.....
answer later.....
no too difficult really - the fact that you were removeing the plug lead has the effect of creating a 'supercharged' spark to the plug , hence the uplift of revs
_________________
the Wrong answer though!
_________________
1342, its only a mini engine!
there is a siamised inlet port between 1 and 2. 3 and 4 have thier own inlet port as well. 2 and 3 share an exhaust port, whilst 1 and 4 have thier own individual ex ports.
"the ex valve had seized in the guide resulting in the valve hitting the piston and destroying the engine"
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
