Aeromotive fuel regulator
Hi all, Where have you mounted your regualtor or have you left it hanging on pipework from the fuel rail. For those of you with guages on your reg what pressure do you have on idle and what shoud it be?? Any pics you can post would be greatly appreciated.
Jam
Jam
Last one we fitted we mounted on a bracket on the inner wing (although this has an electrical sender to send the pressure reading upto the dash)
and this is the reading during a set-up.
Dont forget its a remote regulator so dosn't need to be on the fuel rail
Hope that helps
Hope that helps
