is it possible to.................
change the gearbox oil of an mt75 box while its still on the car ?
also how about changing the oil on front and rear diffs hows it done roughly ?
cheers..................matt
ok if there is / isnt a drain plug how do i top it up again ??????
and the same for the front diff how do i fill it up again ?
is the fill plug for the gearbox in an accesable position ?
the transfer box oil has been changed but the bloke didnt have time to do the other oils,
how often should the oil be changed in the box and diffs ?
cheers guys.................matt
OK
There is a drain plug and a level / fill plug on the gearbox.
Drop bottom cover on front diff to drain, clean mating surfaces, then refit using silicon sealer. Refill through fill / level plug.
On the rear diff, you will need to support the diff with a jack, unbolt the mounting, remove the cover bolts, then loosen and slide the cover down and off to let the oil out. Again, clean the mating surfaces before reassembly using silicon sealer. Refill through the fill / level plug.
