wiring up a water temp gauge ??
Old Jul 20, 2004 | 04:11 PM
220TC's Avatar
220TC
Default wiring up a water temp gauge ??
Hi,
when wiring up a water temp gauge should some sort of 'special' wire be used from the sensor to the gauge ? I've just used normal wire but my mate says you should use a thermal wire or something That could explain why I'm getting low readings, the highest temp i've seen is just below 70 degrees and I'm 99% sure it was way hotter than that ! anybody any ideas.
cheers, Duncan
Old Jul 20, 2004 | 04:17 PM
zvhturbo's Avatar
zvhturbo
No mate just use a decent bit of 250m/a wire.
You don't need special wire.
Old Jul 20, 2004 | 09:03 PM
nomad's Avatar
nomad
you might also get false readings if the temp sender hasnt got a good earth. cheers nomad
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
