leeky water question? escort coss
hi
not 100% sure if it is the head gasket yet, as she's not running warm, is building up alot of pressure in the header tank and water wee bit foamy and dirty. water leek when stopped but unsure where it coming from, running down the front of the block and dripping from around the bottom pulley area, thinkin water pump or thermostat housing. any idea's? could it be the water pump or thermostat housing cracked? or is it the head gasket?
cheers
cheers
Could it be the connection hose between the water pump and the thermostat housing.Mine was leaking from there.If its that, use a silicon hose when you put it back together.Rubber hose tend to go bad as it is quite hot place where its located.
