HELP - ESC COS BRAKE LINES NEEDED URGENTLY
i need some asap, i went to fit my cossie discs and calipers last night, but the banjo bolt is too long for the cossie calipers.
fook knows where to buy shorter banjo bolts from...
anyway, the disc was rusted on to the hub and my constant battering with a hammer has slightly bent the disc i think
(was using a block of wood too)
still couldnt get it off.....
anyway i need some asap as it kinda locks up the drivers side wheel now quite easily
HELP
(was using a block of wood too)still couldnt get it off.....
HELP
well, id need to cut 1/2 of the thread off, and if i packed it wit coper washers they would just compress.
how much for yours mate???
and when can you deliver????
Red_bull
Aug 9, 2015 08:34 AM
