Garage clear out for NEW COSSIE PROJECT!!!
GGR GPA/Philloy front stru brace with MAP bracket £SOLD
GGR GPA rebuildable Dump valve £ SOLD
4x4 I/cooler £60
2x 2wd I/cooler welded together £120
T34 .48, -31 £450 Low miles and max boost 16psi
4x4blue injectors x4 £20?
Rollcage 6point safety devices bolt in, door bars too, White £SOLD
YB inlet valves x3 £10ea
Std cam pulleys pair £15?
2wd exhaust manifold £40 or PX mint 4x4 exh. manifold
Std Airbox cover £?
Rear beam and pair of bare arms £60 set. no hubs
Also to come depending on interest ££ etc,
7.5"rear diff, low miles pinion and crown 3.6:1 £300?
Leather interior 4x door cards 2x seats and r.bench £350?
.75 worn crank
4x4 I/cooler £60
Std Airbox cover £?
.75 worn crank
Drivers seat is worn up the side bolster but not holed, has been repaired there before though. Other seats are in good condition a couple of scuffs but no holes or burns, door cards are lifting at the top a little and front cards have tweeters screwed into them from previous owner
I can post some pics up this week if interested?
I can post some pics up this week if interested?Trending Topics
TPM961
Jan 15, 2018 10:50 AM
M K
Shows & Track Days
16
Nov 8, 2015 06:18 AM
Thanasis
Sep 7, 2015 07:33 PM
