Fuel Leak
Old Jan 22, 2006 | 02:30 PM
aldy's Avatar
aldy
Default Fuel Leak
I have got a fuel leak at the bottom banjo connection on the fuel filter, can you still buy new coppers sealing washers or is there something you can put on the to help them seal???
Old Jan 22, 2006 | 04:02 PM
Pop S1's Avatar
Pop S1
JUST TAKE THE BANJO BOLT OUT OF THE FILTER AND TAKE IT TO HALFORDS OR ANY CAR DIY SHOP AND YOU SHOULD BE ABLE TO GET SOME NO PROBLEM (NOT A SPECIALIST PART)
Old Jan 22, 2006 | 05:57 PM
aldy's Avatar
aldy
Do they have any sort of sealer applied to them???
Old Jan 22, 2006 | 06:08 PM
gee1599's Avatar
gee1599
they are a dry fit
Old Jan 22, 2006 | 06:17 PM
wrcwrc's Avatar
wrcwrc
make there are no bits of crap on either the bolt or the fuel filter where it meets the copper washer.
get a NEW washers in there, dont re use the old ones as they are meant to squash to make a seal.
Old Jan 22, 2006 | 06:23 PM
gee1599's Avatar
gee1599
make sure its not the plastic pipe aswell. also recomend to replace filter at the same time
Old Jan 22, 2006 | 08:06 PM
James Raby's Avatar
James Raby
I've got too many washers, if you want some - PM me
Old Jan 23, 2006 | 09:17 PM
aldy's Avatar
aldy
Didn't read the last post til tonight, got some from a motor factor today, thanks for the offer anyway James
Old Jan 23, 2006 | 09:33 PM
James Raby's Avatar
James Raby
Offer still stands if you need some
Remember they are both different sized diameters...
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
Fudgey
21
Sep 30, 2015 06:19 PM
