Black smoke... is it bad..?
Old Jul 19, 2004 | 08:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Black smoke... is it bad..?
noticed my car is smoking a bit on idle. not constantly but the odd puff of black smoke. cant tell if it does it when driving.
what does this mean???
is it burning lean?
im getting very fucked off with it now
Old Jul 19, 2004 | 08:44 PM
EscortWRC's Avatar
EscortWRC
Black = RICH
Old Jul 19, 2004 | 08:55 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ok, so what do i need to do to sort it??
its got a power boost valve on it, so should i adjust that??
also, its got probe idling at the mo, it seems the breather from the block is collapsing, now i have replaced half of it with some much stiffer tube, but aint got enough for the rest.
could that be causing it???
it wont hold constant revs at idle, it jumps from nearly stalling (sometimes does) to about 1.5k rpm
Old Jul 19, 2004 | 09:39 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Jul 19, 2004 | 10:47 PM
IANS2RST's Avatar
IANS2RST
faulty idle speed control valve , lamda sensor or coolant temp sensor. see if you can borrow some of these to try
Old Jul 19, 2004 | 10:53 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
If the shonky power boost valve is giving more fuel pressure than std (almost deffo is if jus been bashed on without a RR sesh) then thats main reason for overfueling id say.
Maybe it was overfueling a bit which killed the lamda early, which made it worse.
The sensors thing ian said is a good possibility too
Old Jul 20, 2004 | 07:07 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
the power boost valve was fitted by the last owner and it also has a dastek unichip, it has been mapped on a RR.
so the dodgy vaccum wont cause it to run rich while its spluttering away trying to idle then?
Old Jul 20, 2004 | 12:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
