PROBS AFTER CLEANING ENGINE?!?!?
Ive just cleaned my engine bay using autoglym engine and machine cleaner i sprayed it on then hosed it of whilst the engine was running, after id finished i took it for a spin and it started to misfire and idle bad (600rpm), i believe ive got a bit of water in the spark plugs etc.....whats the best way of sorting it...cheers, by the way i left it running for about 10 mins to get some heat going so im hoping the water might evaporate with the heat?
You don't want to go taking spark plugs out if you think that is where the water is sitting, because water doesn't compress. You are just going to have to find out where it is and mop it up.
Look around the metering unit area too, take the cone off if you have one and check the flap.
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
ekjim
Aug 17, 2015 08:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
