HOW RELIABLE IS URS
Ive been scanning through the rs turbo section and ive come to the conclusion that rs turbos are very unreliable especially starting in the morning,when hot,blowing up, generally not starting.....
, is this true.....how reliable woud u say urs is???? ive just bought one and im not looking forward to the future, should i worry??
..cheers
dont forget mate they are getting older 15 years being the youngest model now but generally if you maintain it and look after it doing a oil change frequently it will be okay.
imo, (i've only been an rs owner for a couple of weeks so i'm new to rsts like u)
they can be reliable if u spend plenty of money on them so that everything is working on them right if not replaced with new parts.
I think aslong as u maintain them to a high standard and don't run silly amounts of power the'll see u good.
if u've just bought one i reccommend the first thing u do is get it serviced then visit a rr, it'll cost you around £100 for the rr tune but the operator will be able to point out any probs or weaknesses in ur car
Reliability? Depends on what you call reliable. To me, reliable is a car that I know will start everytime, and get me home.
I bought my car when it was standard 5 years ago, and back then I never had any major problems that you wouldn't expect on a car of that age. It never let me down once I replaced the knackered battery and a couple of other worn parts soon after I got it. If you keep on top of minor maintainence you won't have a problem.
If your idea of reliable is a car that will run and run forever without doing anything to it, keep dreaming. And if your modified RST keeps blowing gearboxes or something because of the mods carried out, then that is your fault. Ford never built the car to run masses of power. So you can't complain.
That's how I look at it anyway
one of mine has vever let me down (its standard , bar a zorst and filter)
my other one lets me down every time i use it (250bhp)
gotta say i like my standard tatty one better
another thing would be is that i would rather have solid bodywork then mechanically wise being ok. if something like a gearbox or engine lets go you could more easily get it fixed then replacing panels and do welding
i use mine daily in ALL weather , sometimes doing 300 miles round trips
ive had a couple of little things go wrong, but see above ^^^^^ i agree with what he said, if you dont use your car often or drive like miss daisy , you WILL get problems
as said, if looked after RST's are very reliable. People buy them, don't look after them, then rag the tits off them and expect them to start first time and never miss a beat.....
most cars would be unreliable in that case
Mine used to give me all sorts of grief. I then found SCC Performance who now look after the car and got it to it's current state. Bar a few minor niggly problems she has been very good. And I can't say I'm too gentle with her.
These are old cars at the end of the day so problems are to be expected
My car has never let me down once
We have used a 2 rs turbo's for a run about for the last 2 years and they have alwys been spot on to never a problem
suppose it depends how ell looked after they are
..cheers
Mines only used for track days,but it laps at 10 tenths for 98% of its time.It is 100% reliable all the time,everytime.The secret is parts are replaced before they break,you cannot skimp on any uprated car or it will let you down.Regards Micky
Indyrs
Dec 4, 2022 12:39 PM
Johnny Knoxville
41
Aug 24, 2015 06:55 AM
