new problem
Old Jan 19, 2006 | 10:08 PM
AKRS1's Avatar
AKRS1
Default new problem
series 2 rst doesnt start after driving it nearly all day today. Turns over but doesnt start seems to be a fuel pump problem. The ignition red lights light up but fuel pump doesnt grind checked fuses in fuse box which are okay anything else i should be looking at thanks
Old Jan 19, 2006 | 10:09 PM
zippyobrien's Avatar
zippyobrien
theres a feul pump relay under the dash. if the feul pump is not primming then this has failed.
the car wont start till you replace it
Old Jan 19, 2006 | 10:10 PM
AKRS1's Avatar
AKRS1
cheers mate where do i look for this relay thanks
Old Jan 19, 2006 | 10:13 PM
zippyobrien
of the top of my head, just stick your head right under the dash on the drivers side.
will have a look on mine in the morning.
there about Ł20 from ford!!!
bloody dear me thinks
Old Jan 19, 2006 | 10:40 PM
AKRS1's Avatar
AKRS1
that didnt take long thanks zippyobrien found purple relay under dash looked clean as a whistle clicked it back on and it started up fine must have been loose thanks again
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
