rear alignment/geometry
Old Jan 19, 2006 | 03:16 PM
opposite lock's Avatar
opposite lock
Default rear alignment/geometry
Hi Everyone can anyone shed some light on an apparently well known issue of the saff cos never being totally straight and true at the rear from factory.
I remember reading about it somewhere ages ago , a company that has a kit that adjusts the setup to fix the problem. inner edges of tyre have increase wear due to the prob although ive never noticed it.
It was only that my friend started going on about it without knowing id read about it , so he,s heard it somewhere aswell
Any info would be gratefull
flint 2wd lattice standard
Old Jan 19, 2006 | 08:13 PM
vyper developments's Avatar
vyper developments
Hi mate,
the scuffing of the inner edges of the rear tyres is caused by hard acceleration, the back of the car squats under power causing the camber angle to go negative (that is the top of the wheels incline inwards at the top) this causes increased loadings on the inner edges of the tyres thus increased wear in this area.
This is not a problem with suspension geometery a lot of cars with similar rear suspension show this trait.
CheeRS, Mike.
Old Jan 19, 2006 | 09:50 PM
JamesH's Avatar
JamesH
Originally Posted by vyper developments
Hi mate,
CheeRS, Mike.
Totally correct!
I'm fitting Ahmed spring into Koni shocks, and rear Shims (all from MikeR). This should not lower it TOO much, and cure about 50% of the wear problem
Old Jan 20, 2006 | 02:03 PM
opposite lock
Hi mate,
CheeRS, Mike.
Ah right thats where the rumour has emerged from . Sorry Ford for suggesting such a thing !! thanks for that info .Gonna re bush the lot at the back and perhaps one of them new style rear diff hanger as read that they can cause some movement when old.
cheeRS Mike.
Old Feb 16, 2006 | 11:08 AM
coswol's Avatar
coswol
any photo?
Old Feb 18, 2006 | 01:42 PM
2001ode's Avatar
2001ode
Hi,
Some pics, all dimension in millimeters.
Claude
Old Feb 24, 2006 | 08:04 PM
coswol's Avatar
coswol
great
thanks mr.
Old Mar 28, 2006 | 12:33 PM
VICFR2's Avatar
VICFR2
Default Sierra rear camber
vyper developments
Hi
Are you the MikeR that sells the rear camber shims for a XR4x4 2.9?
Thanks
Vic Roper
Old Mar 28, 2006 | 08:10 PM
JamesH's Avatar
JamesH
http://randbmotorsport.co.uk/shop/De...?ProductID=178
For a Cossie
Old Mar 29, 2006 | 03:12 PM
EricYellow's Avatar
EricYellow
Anybody got some pics on where these shims go ?
Or even better, a mounted set of shims
I've been looking at some pictures of the rear suspension but can't really place them....
Old Mar 29, 2006 | 08:20 PM
JamesH's Avatar
JamesH
You have to take the rear disc's off, then they go behind the rear hubs
Old Mar 29, 2006 | 09:12 PM
rapidcossie's Avatar
rapidcossie
i have the rear shims but did not fit them.
after a bit of thought surely they would cause the brakes to wear unevenly as the caliper is bolted to the hub, which will no wbe at an angle due to the shims?
Old Mar 29, 2006 | 10:55 PM
robrs2's Avatar
robrs2
The shim goes between the hub and the arm, does not affect the caliper to disc position.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
