water leak
Jan 19, 2006 | 01:19 PM
water leak
found water dripping over the o/s/f speaker grill, wots the most likely place its coming from?
Jan 19, 2006 | 01:45 PM
Rotten window (bottom corner)
door seal
fuse box/battery tray.
Jan 19, 2006 | 03:07 PM
Either of the above mate
Jan 19, 2006 | 03:52 PM
Jan 19, 2006 | 08:21 PM
depends what one, but out of the 2 it's welding and dash out job
Jan 19, 2006 | 09:02 PM
try sealing up the base of the fuse box....easiest repair to try first....failing that ..pull the fookin dash out....
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
