LOW COMP AND HEADGASKET
Old Jul 19, 2004 | 01:01 PM
paulp's Avatar
paulp
Default LOW COMP AND HEADGASKET
Just had to change my rad on my s2 and it was distorted and bowing out at the top and bottom,the bloke in the shop said it could have been an air lock or the headgasket might have gone.
If it is the head gasket will it be a different one than a standard one cos my engine has low comp pistons in it,any advice will be greatly appreciated
Old Jul 19, 2004 | 01:02 PM
R4N SS's Avatar
R4N SS
its probably an uprated gasket
Old Jul 19, 2004 | 01:05 PM
CabrioTurbo's Avatar
CabrioTurbo
you can get much better than a standard ford head gasket, and unless you have a 1900cc engine then dont use the felpro one.
CheeRS
Phil
paulp's Avatar
paulp
when you say uprated does that just mean stronger gasket,or i thought it might be a difference in thickness of the gasket if the head was skimmed
Old Jul 19, 2004 | 01:11 PM
CabrioTurbo
IIRC cometic are the only people to do thicker headgaskets for the RST and they are quite expensive.. i doubt it will have one of them.. more than likely its going to be a standard ford one on there.
Old Jul 19, 2004 | 01:20 PM
Paul Eggleton's Avatar
Paul Eggleton
DOn't worry too much about a bowed rad unless its really bad. A brand new one bowed straight away on mine, Karl recomended putting a band around it
Old Jul 19, 2004 | 01:27 PM
paulp's Avatar
paulp
how can you test without taking the head off that it is gone? theres no mayonnaise in the oil cap,no white smoke coming from the exhaust and it doesnt overheat, but i have noticed in the water resevoir that it has got brown froth on top of the water, like the head on a pint
Old Jul 19, 2004 | 01:45 PM
paulp's Avatar
paulp
btt
Old Jul 19, 2004 | 02:00 PM
CabrioTurbo
you can do a compression test to check that compression in the bores is good if it has blown on 2 adjacent cylinders then they will both be down on compression.
Old Jul 19, 2004 | 02:01 PM
paulp's Avatar
paulp
cheers
Old Jul 19, 2004 | 02:26 PM
CabrioTurbo
may also be worth crack testing the block with tracer dye
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
