Help...Cossie Misfire
Old Jul 19, 2004 | 11:08 AM
Sticky.'s Avatar
Sticky.
Default Help...Cossie Misfire
Put it up in the technical part, but to no joy
Totally standard cossie, & it's misfiring to fooook
Its soaking number 1 & 3 plugs, ive changed the leads/plugs & the injectors around incase it was the injectors weeping, but it still doing it.
Could it be map sensor or cooling temp sensor
Any advise would be appricated as im hitting a brick wall now
Old Jul 19, 2004 | 06:06 PM
Sticky.'s Avatar
Sticky.
Someone must no ..........anyone
Old Jul 19, 2004 | 06:34 PM
Lee Reynolds's Avatar
Lee Reynolds
Does sound like a sensor causing over fuelling! Which one is hard to tell.
Old Jul 19, 2004 | 06:55 PM
Sticky.'s Avatar
Sticky.
Ive just changed the cooling temp & air charge, but its made no difference.
Gonna have to find a 2nd hand map sensor i think & try that.
Old Jul 19, 2004 | 06:56 PM
Lee Reynolds
Aye My escos was the map. Very bad overfuelling.(well it was the 3 pin connector to map, not THE map)
Old Jul 19, 2004 | 07:05 PM
TIFF's Avatar
TIFF
Chasing Radders
Paul
Do you need a 2 bar sensor?
Sticky.'s Avatar
Sticky.
Ive checked all the wiring & connections Lee & seem to be ok.
Come on peeps the quicker i get it fixed the quicker you get to see TIFF'S 3dr Zebra'd up
Old Jul 19, 2004 | 07:08 PM
TIFF's Avatar
TIFF
Chasing Radders
If you need a 2 bar map sensor Paul, i will have one you can use when Karl does my car on Thursday
Old Jul 19, 2004 | 07:13 PM
Sticky.'s Avatar
Sticky.
That would be great that Mark if i get one before hand, i'll let you no.
Old Jul 19, 2004 | 07:14 PM
TIFF's Avatar
TIFF
Chasing Radders
No problem mate, i will let you know when i have it spare and i will post it up to you
Old Jul 19, 2004 | 07:16 PM
Lee Reynolds
Paul, i checked the wiring for 3 months on the escos including an Auto sparky twice and could not be traced. I stumble upon it being fooked, was no clear evidence!!!!! Way i found out was i wired the MAP direct from the ecu.
Prob worth tryin a map first tho!
Old Jul 19, 2004 | 07:19 PM
Sticky.'s Avatar
Sticky.
Lee if it's not the map sensor, how do i go about wiring it direct to the ECU
Old Jul 19, 2004 | 07:31 PM
Lee Reynolds
You need a wiring diag( lost mine) of the ecu. You find out which wires go to the map. One is live feed, one is earth and the other sends the info to ECU. So i got a new 3 pin conector, wired it direct to the ecu/live/earth and ehy presto fired up and ran sweet.
This told me there was something wrong with the wiring to the map. Tested the wiring with a multimeter and it was all ok, so this told me it was the 3 pin conector! Soldered the new one on and was fine then till i sold it!
Old Jul 19, 2004 | 07:37 PM
Sticky.'s Avatar
Sticky.
Cheers Lee, i'll try & get hold of a wiring diagram & try that if its not the map sensor.
Cheers for the advise
Old Jul 19, 2004 | 07:39 PM
Lee Reynolds
NP. Electrical probs are a night mare i was pulling my hair out!
Old Jul 19, 2004 | 07:42 PM
Sticky.'s Avatar
Sticky.
Im getting that way Lee just want it ready for ford fair
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
