Who using cossy Man?
Ive tried looking but I cannot find one with everything on it...
I need a complete list of parts that I will need and any mods that need doing.
I could really do with some help.
Thanks,
James
Thanks,
James
JamesS2RS
you been on oddkiddcreations??
he s got a downloadable spread sheet with all the parts and prices!
i ve done the conversion my self and so have a couple of me mates and it isnt hard!
Originally Posted by Davey8oy
JamesS2RS
The parts i have are: -
Loom Cosworth 2wd
ECU Cosworth 2wd
Throttle Body Cosworth 2wd
Ignition Amplifier
Fuel Regulator Cosworth
Injectors STD Cosworth 2wd / 4x4
Efi Inlet manifold Modified
Bit i no i need to buy
top sensor bracket & phase disc & sensor
Bottom sensor bracket & sensor
Alternator & bracket
Bottom pulley & trigger wheel
crank sensor
phase sonsor
Throttle Position Switch Cosworth 2wd / 4x4
Idle Valve Cosworth 2wd / 4x4
Is there anything else?
Jim
im doin this conversion at the moment and lets just say, theres bloody loads of bits u need to buy, more than u think, if ya gona do it properly ie no expense spared.
definetly go to jano at oddkidd creations for any advice
Russ Payne
Sep 25, 2015 08:29 PM
