when setting the base timing...
Old Jul 19, 2004 | 10:32 AM
Jim Galbally's Avatar
Jim Galbally
Default when setting the base timing...
how important is the RPM?
my car idles at 950ish RPM and it should be 900rpm
since i dont have a timing light with a proper RPM display on it i wont be able to get it bang on 900
will this massively effect things when i go to set the timing? or 50ish rpm considered to be "within limits" ?
Old Jul 19, 2004 | 10:36 AM
Stu @ M Developments's Avatar
PassionFords Creator
950 will be fine.
Old Jul 19, 2004 | 10:40 AM
Jim Galbally
1 more quicky for you stu... one of my tappets is quite... erm... tappety
is this likely because i didnt set that one correctly when i did em the other week?
Old Jul 19, 2004 | 11:14 AM
Very
Old Jul 19, 2004 | 11:16 AM
Jim Galbally
joy
anyway emailed you about hopefully getting the car up to you in august for a professional to do it properly
ie deffo not me
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
