electrical probs.....HELP
Old Jan 15, 2006 | 07:28 PM
martinmace's Avatar
martinmace
Default electrical probs.....HELP
right lads
my fuel gauge on my s2 always goes to full and stays there.but if i turn on the rear demist it flys right down the bottom fast where do i start looking to sort this out also the abs light stays on and also comes off when the rear demist is switched on. fucking car
Old Jan 16, 2006 | 06:09 PM
©hatter Box's Avatar
©hatter Box
i would say try changeing ur water temp sender in the head about 14 pounds from ford
Old Jan 16, 2006 | 06:54 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
call
or run a simple earth from the bootlid to the car body, see if that helps, just bodge it at first cos it may not help, im assumning the demister earth is duff and its goin thru the other circuits to earth (hinges dont make good earths and the wirin that runs thru is easily busted)
Old Jan 16, 2006 | 06:56 PM
1.9 xr2 on 40's
st170 breaking
rereadin ur prob it may be the other way round and the sender is earthing wrong (maybe via the fuel pump supply to make it go to the top straight away), try putting a better earth to that too (could patch in under the rear seat to a good earth to see if that sorts out the gauge problem)
Old Jan 16, 2006 | 07:04 PM
SafeChav's Avatar
SafeChav
Originally Posted by 1.9 xr2 on 40's
call
Sorry but......U SAP lol
What he says makes sense (bar the ghostbusters bit )
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
