cossie problem
Old Jan 15, 2006 | 02:28 PM
nice_head's Avatar
nice_head
Default cossie problem
Booted my cossie lastnight and then it started to run on 3, checked all the plugs and the plug in port 3 was covered in oil..
Any ideas?
Old Jan 15, 2006 | 02:53 PM
pee vee's Avatar
pee vee
dont sound good mate
could be
Melt down on that cylinder,
Headgasket
something like that
either way, sounds like head off time to see
EDIT:
did you mean the Tip of the plug was covered in oil? so the cylinder
has oil in it?
or as in cam cover gasket failure? so the Spark plug well was full of oil?
Old Jan 15, 2006 | 05:01 PM
nice_head's Avatar
nice_head
Ive been told its probably a valve gone
Old Jan 18, 2006 | 09:32 PM
whitecossie's Avatar
whitecossie
u need the head off mate or maybe a compression test ..
Old Jan 22, 2006 | 12:30 PM
black3door's Avatar
black3door
MINE DID THE SAME THING ABOUT 6 MONTHS AGO MATEY, TOOK HEAD OFF AND FOUND NUMBER 4 PISTON HAD MELTED DUE TO RUNNING LEAN.
HAVE YOU HAD IT COMPRESSION TESTED YET?
Old Jan 22, 2006 | 05:45 PM
nice_head's Avatar
nice_head
Done at piston before and it was smoking like crazy so dont think its that..
Booked in at engine advantages this week..
Old Jan 22, 2006 | 07:53 PM
twitchyrear's Avatar
twitchyrear
good luck mate,hope it doesnt burn a hole in your pockrt to fix it
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
