Right, BSOD is pissing me off now :wall:
Old Jan 15, 2006 | 11:28 AM
Thrush's Avatar
Thrush
Irritating c........
Default Right, BSOD is pissing me off now :wall:
Since installing the Widcomm bluetooth stack and plugging my bluetooth USB dongle in I have been having problems with this "Blue Screen Of Death" that for no apparent reason with no warning suddenly shuts down the PC with a blue screen with white writing on it saying that Windows encountered a serious error and has shut down to avoid damage.
This has to be a hardware issue and not a software issue, as it always mentioned a piece of hardwareis not working or something to that effect and I get this message in on the screen
IRQL_NOT_LESS_THAN_EQUAL
I think it HAS to be the actual BT dongle itself. Cos I had this happen only when the dongle is plugged in, both this recent installation time and last year when I tried it. Both times it was with different software the only thing that is the same is the dongle itself.
Any idea's before I wipe the fucking thing and reformat the machine? Is it worth spending money on another BT dongle that might not cuase conflict with the PC and cuse this BSOD? If so, which one and how do I know it won't just have the same internals as the one I have, just in different packaging?
Cos it's pissing me off now, cos it happens with no warning and anything I haven't saved just gets lost
Old Jan 16, 2006 | 08:30 AM
DanRSturbo's Avatar
DanRSturbo
Send the dongle back and get either a refund or a different one. And also format the fucker
Old Jan 16, 2006 | 09:17 AM
Thrush's Avatar
Thrush
Do I have to format it? It's a fucking pain
And for the hassle it ain't worth sending the dongle back. Had it since November or whenever it was but not really used it as I didn't like the HID/software it came with... And it's from fooking China or Hong Kong or somewhere so it'd cost too much, might aswell buy a new one... But which one!
And do I have to format? Other than this it's (the PC) absolutely fine!
Old Jan 16, 2006 | 09:20 AM
EssexBoyRacer's Avatar
EssexBoyRacer
Thrush, have you tried using the BT dongle in another USB port? (you might have to go through the drivers sarga again). Might be worth a try.
Old Jan 16, 2006 | 09:25 AM
Thrush's Avatar
Thrush
Yeah I did that yesterday as it gave the BSOD three times in as many hours!
So I swapped it to another port, and whilst it didn't crash, it did ask me to reinstall a driver for it......
I will find out later when I get home and boot it up if it works from boot up in this new USB port. It hasn't been working in the one it was in, I would boot up and it would say "no device connected" so I'd have to pull it out and plug it in again... Then 10 mins later it would BSOD....
So we shall see later......
Old Jan 16, 2006 | 10:46 AM
EssexBoyRacer
good luck m8.
Old Jan 16, 2006 | 10:59 AM
DanRSturbo's Avatar
DanRSturbo
I personally would get another Bluetooth dongle and also wipe the machine clean and start again, just to be on the safe side
Old Jan 16, 2006 | 11:10 AM
Thrush's Avatar
Thrush
Old Jan 23, 2006 | 12:50 PM
bcracknell's Avatar
bcracknell
having exactly the same issue with a machine at work.
It's a driver problem, about 2/3rds of the way down the screen should be details of the driver file causing the problem.
be damned if I can work out how to fix it thought!
Old Jan 24, 2006 | 09:30 PM
Stu.H's Avatar
Stu.H
i blast the machine every month anyway which is how any pc shud be done to obtain maximum speed
tiffs must be like my old xr2 now
Old Jan 24, 2006 | 10:01 PM
Thrush's Avatar
Thrush
Well mines been good as gold since I reinstalled it all and changed the bluetooth usb dongle. Only thing is it won't let me manually install the new USB dongle, it auto installs which is fucking annoying as I want to run it using the Widcomm stack not the poxy built in Microsoft stack
Old Jan 24, 2006 | 10:33 PM
timb551's Avatar
timb551
Have you tried turning on "use legacy usb" in the bios. Seemed to remember this solving something along these lines a while back.
Also some motherboards have a jumper which can be set to feed more power through to the usb ports at the back. Sometimes altering this can help.
Just a couple of ideas, hope they help.
Tim
Old Jan 25, 2006 | 08:15 AM
DanRSturbo's Avatar
DanRSturbo
What power is your power supply thrush ??
Old Jan 25, 2006 | 10:50 AM
EssexBoyRacer
Thrush if you want to use the widcomm stack you have to manually disable the microsoft bluetooth device from within device manager. Then install the widcomm stack.
Old Jan 25, 2006 | 11:49 AM
Thrush's Avatar
Thrush
I did that. I installed the Widcomm stack the way I did before (install, boot into safe mode, swap the 4 files over, reboot)
Went into Device manager, and one the bluetooth entries I selected "do not use this device)
Then unplugged the bluetooth dongle and plugged it back in.
But the problem is Windows automatically assigns the driver without letting me specify it. It doesn't open up the new hardware wizard like it did before, it just pops up the balloon in the task bar, then says "driver found" and installs it to the MS Stack. It doesn't give me the option to search from a specific location
Have a look here : https://passionford.com/forum/viewto...ight=bluetooth
martynhomer01
Oct 1, 2015 12:05 AM
dojj
Sep 29, 2015 10:32 PM
paceo
Sep 25, 2015 08:05 PM
alexbarnes95
11
Sep 15, 2015 10:26 AM
