alternator/crankshaft pulleys.
HI,probably daft question but should i be able to turn both above pulleys easily?.just gone through 2nd drivebelt in as many weeks.Almost sure alternators knackered,but unsure bout crankshaft.Thanks all,Rob.
not sure if this is much help mate
when the engines runnin with belt on
is everythin stayin lined up, sometimes they can buckle or move which caused me 2 go thru loads of belts til i bought a new pulley for the belt to sit on and hey presto
the bottom pulley will be hard 2 turn due to compression in the engine, and ur alternator should turn freely (try spinnin the alt pulley and listen for any whizzing noises or roughness)
again hope this is atleast a bit of help mate
Thanks for that mate, all sorted now.Was alternator,for once big up for Halfords .Re-con £65 with £25 back when i return dud one.Got quoted 35 plus vat from scrappie,and that was taking it off myself.So well pleased. Rob.
Stu @ M Developments
Trader Parts for Sale.
Aug 19, 2011 02:54 PM
Apr 6, 2011 07:24 PM
Davemurphy007
Mar 11, 2011 09:31 AM
