My turbo to manifold is blowing slightly, do I need to replace the nuts when I refit it or do I need new ones? Also is there any thing I can put between the faces when I refit it to make it last a bit longer
apparently there is something that you can get from Garret but 99% dont have anything between ther due to the extreme heat. have you tried tightening the nuts?
i also got this problem with mine, looked at it the other day and the nut was almost off!!! one of them is a bit of a bitch to get to the init? i may take it all off and give it a good old clean! sould solve the problem,
