Sierra Cosworh 2wd Rear Lights Question
One of my break lights is out, so bought a new bulb from fords, didnt solve it ok went n got another still didnt do it , all the other lights in the bulb holder that you put into the rear light work, my guess is that the bit you put the bulb into is knackered ?
my question is if i went to a scrappy to a 2.0 sierra or something and took out that plate bit that you put the bulbs into will it work in the cossie ok ?
or does it specifically have to be a cossie one
they are all the same
but it's possibly the connecter thats faulty, clean out the plug and see if this fixes the prolem, disco lights on the rear are mainly earthing problems due to this plug
sridgett
15
Aug 3, 2015 07:26 PM
