Escort Cosworth Monte 014/200 Harvey Gibbs/AB 375BHP engine
Right its been bought to my attention the old "For Sale" thread had become a little confusing, being 3 pages long etc, so I thought it best to start a fresh!!
Ford Escort RS Cosworth ‘MONTE’ Number 014/200
1 of 74 right hand drive limited run commemorative Monte editions, now becoming extremely rare.
Build date commenced February 1994. Registered 1st August 1994, making this car one of the very last Large Turbo models.
I have owned this car since August 2002, after a long search to find the right one, in that time I have covered approximately 15,000 miles.
There are two previous owners, NEITHER were a main dealer, the second had owned the car from May 1996.
I have contact details available for both (to serious interested parties only).
Two A4 binders contain a FULL detailed and concise history totaling in the region of £25k in receipts and invoices including all previous MOT’s, detailing the 112k mileage.
A further £8-9k (PLUS Labour) has been spent on the car since June 2005, due to a melted piston.
Extremely well cared for throughout its life, I would suggest the car could safely be described as in immaculate condition throughout.
HPI Clear.
Never been welded, never been involved in an accident.
MOT till April 2007
Any inspection welcome (I have access to a ramp so car can be viewed in the air too)
Registration;
M3NTE
Body;
Mallard Green, with factory coluor coded door handles and fuel filler cap.
Waxoyled heavily throughout.
Gold coloured “Monte” logos on doors and bootlid, with an additional “serial number” decal on bootlid, rear “Ford” badge removed.
Morrette twin front headlights, dark smoked front fog lights, indicators and side repeaters, half smoked rear lights.
Colour coded front splitter.
CAT I alarm and immobiliser, incorporating window roll-up, dual zone proximity sensors, anti hi-jack etc and GPS tracking device (all fitted in 2002)
Interior;
Full Lux spec, with original (specific only to the Monte) cloth recaro interior (leather was not a factory option)
Factory fitted electric sunroof.
Standard Monte gearknob and handbrake button.
Custom made leather gear gaitor
Build number on dashboard.
Dash mounted Pectel control systems “Boost Pot”, allowing 12 position boost adjustment.
SECS Monitor fitted in custom made dash panel, buttons for this are mounted on the steering column shroud.
Original factory fitted 2000 radio cassette and optional in dash CD player (not shown in pictures).
(Kenwood not included)
Engine/transmission;
Full Engine rebuild by Harvey Gibbs at SCS, this was installed in car in August 2005 and has done 3000 miles (1k of those was running in, a further 1.5k on 12Psi Boost MAX).
Consisting of;
New oil pump, gaskets etc
BRAND NEW long studded 200 block.
Big wing sump baffled and windage tray, additional oil return union fitted.
Standard crank (Unground)
Brand new Mahle pistons, machined for lowered compression and valve cut outs (7.6:1)
Genuine WRC 4 layer steel Headgasket.
(bottom end good for 500 BHP)
Minor headwork around valve stems.
Obviously complete head rebuild including new lifters
Custom made Black Ignition leads
Dizzyless ignition (New Ford coilpack)
New light blue bosch injectors
T3/04 Turbo rebuilt incorporating 360 Thrust bearing
Genuine WRC Air to Air injectors, mounted on custom made bracket, hoses to/from these are fully braided with aeroquip fittings.
All pulleys have been Nickel plated.
Custom made Billet Alloy fuel rail, with Aeroquip unions and braided fuel lines
Aeromotive adjustable fuel pressure regulator.
Pro Alloy RS500 style intercooler, which has been “Boxed” up to a genuine NEW Behr radiator.
New Bosch “023” high flow fuel pump.
3 Bar MAP sensor
Custom made Pectel control systems Engine loom, the original has been FULLY removed.
Pectel board in P8 ecu running a Harvey Gibbs/Ahmed Bayjoo, Dyno / Live map.
Engine made 375BHP and 380 lb/ft Torque in SCS’ Dyno cell.
Power Engineering Stainless steel exhaust system, Lambda Boss welded in downpipe, car also comes with a Power engineering stainless freeflow sports CAT MOT compliant
K&N ‘Monster’ cone induction kit and polished alloy trumpet.
Cam cover painted in body colour.
Alternator, starter motor and Front Diff have been painted in 2 pack silver and clear laquer
Powdercoated Subframe, alternator bracket, inlet manifold, thermostat housing and MAP sensor bracket.
Blue Samco boost hoses.
Black Samco ancillary water hoses.
GGR/Tarcal polished stainless, water header tank, mirror breather catch tank and 4 port breather kit, all with threaded unions/connections and aeroquip high pressure hoses.
Additional Main water hoses are blue Samcos.
Polished swirl pot
New Alcon six paddle clutch plate using a genuine Ford/AP clutch cover.
Gearbox recently replaced.
Quick / short shift gear linkage.
Suspension/Brakes;
Koni springs and dampers, 25mm lower.
Polybushed throughout.
Polished stainless steel dual spar strut brace, polished strut tops.
Powdercoated ARB and brackets
Front: AP Racing cp5200 4 pot calipers, recent AP Racing 315mm grooved discs Mintex pads.
Rear: Standard sized grooved rear discs recently replaced new calipers.
Steel over braided brake lines.
Wheels/Tyres;
Standard limited edition genuine Ford O.Z Racing alloys 8x16, with no signs of corrosion and no curb damage what-so-ever, the original "O.Z. Racing" graphics are still as they were when new, i.e. pressed on below the clear lacquer
Front tyres Avon CR228's, rears are Toyo Proxes T1-S, all in excellent condition as they have done far less than 3000 miles
I think that’s everything, I will add more as and when I remember.
For further extensively detailed pictures , including the sills, underneath and other bits you arent usually able to see, see this thread in the restoration section;
https://passionford.com/forum/viewtopic.php?t=111256
Graph and chart from Harveys Dyno cell
If you want any other pics let me know
reply here or PM.
HPI Clear.
MOT till April 2007
Registration;
M3NTE
Body;
Interior;
Consisting of;
3 Bar MAP sensor
Polished swirl pot
Suspension/Brakes;
Wheels/Tyres;
reply here or PM.
Originally Posted by ian rst
I know i am adding to this but this is why the last post got to 3 pages long just people commenting him on it, Pm damo to tell him things like that.
Rant over.
Rant over.Reason I scrapped the old thread was because it mentioned the engine melting etc, I had someone ring me ask me if it was the new engine etc
Cheers for ALL the comments people
Originally Posted by silky16v
hi has the car been for it's final setup yet or is this still yet to be done thanks
Well tbh I havent exactly been forcing the for sale issue.... Partly because Im not finished etc etc and want it featured and subconsciously probaly dont really want to get rid
MUST get my arse in gear
Originally Posted by Damo V
Well tbh I havent exactly been forcing the ofr sale issue.... Partly because Im not finished etc etc and want it featured
You sound like me, I was looking at pics from a car show last Sept, E38, my car had For Sale signs in it then, kept changing my mind
Look forward to the feature, Im sure plenty of people would like to see yours at the shows as well
Originally Posted by Cola
TTT - what ya getting Damo?
Mate seriously IMO its too nice to sell. You have so much fun when out at the RSOC meets / shows i think you might miss it ALOT
Very interested in your car, wondering why it hasn't been sold yet. can you ring me on 07852222271 as i dont have regular access to the internet, my names stewart and you can get me on the above number anytime.
Thanks
Stewart
Thanks
Stewart
jaiscossie
Jul 4, 2014 08:04 AM
very nice
