BOOT RELEASE??
Old Jan 7, 2006 | 06:40 PM
COSSIE 1's Avatar
COSSIE 1
Default BOOT RELEASE??
Were any of the series 2 erst fitted with electronic boot releases /like the fiestas mk3s or were all of them just opened by the key? the reason im asking is i can see a solenoid attached to the arm going to the lock an im wondering how its activated/used, i havent got any ovious switche that i can see thanx
Old Jan 7, 2006 | 07:19 PM
Just with the central locking as standard ,is the bootlid delocked ,then it may have another one fitted ,to operate from a switch or a fob
Old Jan 7, 2006 | 09:27 PM
Micky's Avatar
Micky
The solenoid you can see is to locl/unlock the boot with the central locking.You dont need an electronic boot release on a Escort because the boot will open without a key if the doors are unlocked.Regards Micky
Old Jan 7, 2006 | 11:16 PM
COSSIE 1's Avatar
COSSIE 1
mmmm thats what i thought, thing is the boot will lock with the key but it wont unlock, when i activate te alarm the boot doesnt lock/unlock and when i unlock the car with the key the boot doesnt unlock, is there a relay/fuse just for the boot somewhere or does it work as a full system? regards cheers....also are these common in playing up??
Old Jan 8, 2006 | 12:41 AM
Sounds like a dodgy or sticky solenoid,trip to the breakers needed ,no relay or fuse that i know of ,would affect the whole system if it was a fuse.
Old Jan 8, 2006 | 07:57 AM
COSSIE 1's Avatar
COSSIE 1
cool if i can get it working then it will save me having to change my boot lock as it will lock ok but it wont unlock!! , cheers peeps
Old Jan 8, 2006 | 01:30 PM
Turbo-T34's Avatar
Turbo-T34
I had this problem, there should be a metal piece of wire between the solenoid and the actual lock, which is used only for the central locking.
When activated, it pushes the wire, which in turn pushes the lock down, so locked. When unlocking, it pulls the wire thus unlocking.
I bought an xr3i with this problem, any escort with central locking should have this piece of wire.
If you need more info send me a pm.
Old Jan 8, 2006 | 02:25 PM
dave_y's Avatar
dave_y
ok here is a picture of the things in question.
the yellow circle shows the wire which pushes the lock open
the blue arrow is the solenoid?
my lock only works off the key so im guessing that i need to get a new solenoid. when i do the central locking i get no noises or movement from the tailgate lock region.
Old Jan 8, 2006 | 05:25 PM
COSSIE 1's Avatar
COSSIE 1
when i move the lock from inside the boot the solenoid wire/bar moves so its all connected, ill do a circuit test to see if ive got power going to it, ill post up when ive done some more investigating
Old Jan 9, 2006 | 07:30 PM
RoBoX's Avatar
RoBoX
if you don't figure it out they sell universal boot unlockers if you didn't know.. thats a really great security investment.. the boot lock on the mk4 is horrible when you want people to stay out of there..
Old Jan 11, 2006 | 09:54 AM
COSSIE 1's Avatar
COSSIE 1
after assing about with it found out when i locked it at the drivers door that it does indeed work when u lock/unlock from the drivers door
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
chris m1
Sep 7, 2015 08:02 PM
