S2 Rear Brakes Help!!!!!!!
I've brought some brackets to convert my rear brakes to disc, but there
are no instructions!!
The brackets fit where the back of the drum was (4 bolts), the bracket has
4 threaded holes as does the hub bit on the car, do i need to drill out the
threads on the car and bolt through from the back??
Anyone done this as i'm a bit stuck!!
Dan
Dan
