just a normal day at work 66ton 90 foot long
yeh the company i worked 4 b4 was police contracted so c fatals all the time been in news clips and photo in papers
but didn't never bother me any ov that u get use 2 it
i used to do recovery - lift n shift was quite easy really, coaches are hard ifyou have to low load them, but the best ( or worst ) are units on there side, you have some very heavy equipment at sparks iirc - some nice gear, have you got any large holmes overhead booms , i used a unit once , a renault magnum with a massive underlift, huge grids on the back to keep the fooker stable when using the twin over heads for righting commercials.
tis an art to right a unit without it going back over on you
the screen cost loads aswell
Croppy thats your averege ERF ECT broken down,used to work for erf/man .now moved to SCANIA road side jobs are the best,hate being stuck in work shop
cheeRS stu
cheeRS stu
MARK the old company i worked 4 i drove a daf2800 old beast wiv and had holmes 750 converted to hydraulic proper winching tool
STUCOS
funny that coz in 9 years hardly ever go out to a scanny
recover ect'c/tga loads
use to be clutch's be 4 they all got fitted wiv modified clutches
DAN
recovery is totally dif m8 trucks r plated different don't even ave to use a tacho
reversing them u get use 2 i can do it but need plenty ov room and r limited 2 where u can put it 4 obvious reasons
STUCOS
DAN
Originally Posted by Dan
Thought that size lorry was 44t Gross Weight?
44t truck on the back of a 20t recovery truck, combined length of 90 foot...
Got ya! lol
Originally Posted by croppy
DAN
with that truck i can't pic up a fully loaded tipper well i can but not safe as ur picking up alot ov weight
wheres as an artic i'm only picking up the cab bout 7ton roughly and pulling the rest
with that truck a 44 ton artic is bout the weight limit but have towed heavier low loaders
obviously u need to brake the towing vehicle if heavy so there brakes assist
steerfromdarear
28
Jan 29, 2016 06:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
