head gasket question
Old Jan 5, 2006 | 08:12 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default head gasket question
rst btw
can a head gasket be fooked even if u have good compression on all 4???
my rst is pissing out steam and running on 3 but compression is good on all 4 but spark plug on pot 1 seems to have bits of wet water on it.
Old Jan 5, 2006 | 08:16 PM
Rick's Avatar
Rick
is it bubbling the header tank?
Old Jan 5, 2006 | 08:17 PM
Roosie's Avatar
Roosie
havent had a good look will do in morning
Old Jan 5, 2006 | 08:35 PM
EIL132's Avatar
EIL132
If it's blown into the cylinder then the compression will be fine, however water pressure will be high
Old Jan 5, 2006 | 08:42 PM
FingerZ!'s Avatar
FingerZ!
pretty much one of the most common symptoms of head gasket failure - if its got lots of steam even when warm commin out of the exhaust then thats a bad sign of failure, if its got a missfire with water in the cylinder/plug but compression fuel n ignition are good then thats another bad sign
the other is water n oil mix but sounds like you have just got a leak between the cooling system and a cylinder
when the heads off, obviosuly do a skim, but make sure you check that the block sint pitted around the water holes - common thing is to have a head gasket n skim n the problem still being there cos the block has been eroded away!
Old Jan 5, 2006 | 08:43 PM
Oranoco's Avatar
Oranoco
My old XR2i hydraulic'd. That was fun, fortunately it happened on the drive while turning over rather than when running
Old Jan 5, 2006 | 08:44 PM
Roosie's Avatar
Roosie
tbh it happend n\just after i hit the rev limiter and my engine give a big backfire then all went downhill
Old Jan 5, 2006 | 09:40 PM
abdr500's Avatar
abdr500
could be a cracked head or block
Old Jan 6, 2006 | 09:12 AM
Roosie's Avatar
Roosie
ill get my head of later and see what the damage is
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
