Wheel alingment ?
As above went to get this done today , as my steering wheel shakes at around 50ish but i lose that about 80ish and my steering wheel sits slightly off centre
Anyway went to get this done today and they told me iL need my front bumper off to do it as its too low/splitter etc etc
cant get guages or something on wheel
Shit , is there any wy round this
I assume the place you went to are still using the old gear with scales and little mirrors?
If so, find someone in your area who uses the laser alignment system, they just clip the units onto each wheel and away you go.
Leigh
Leigh
Check out the Farmer Autocare place nearset you. The one near my folks has a laser wheel alignment system.
http://www.farmerautocare.com/locations.html#
Give them a ring mate, see if they have one in the glasgow place.
Leigh
Leigh
I would check wheel balance first, especially on the back if you tend to pedal your car hard, make sure the tyres arent out of shape! This would give you severe vibration at speed. As for your steering wheel off centre this is probably unrelated to your vibration problem and could be worth having the tracking checked, Go for laser alignment this is the way forward with tracking. If you have poly bushes up front have it set for parallel.
Mike.
Mike.
Rs500 DataBase Editor
From: In the Karate Dojo , or updating the rs500 database
my saph to had this problem
i had the wheels balanced it was still the same
it turned out that the n/s caliper was sticking very slightly, recon caliper jobs a good un.
Karl @ FPT
Sep 21, 2015 11:17 AM
Adam Graham
Sep 6, 2015 06:04 AM
