Con Rods
Do you think these will be fine to put into any 2.0 zetec lump?
I no it says focus but will it make a diff?
http://www.newedgeperformance.com/in...PROD&ProdID=43
http://www.eaglerod.com/products/For...yl%20rods.html
Jim
Jim
if you mean in a silver top engine? then no, unless you use correct pistons.
black tops use longer rods and sorter pistons (or shorter rods, longer pistons, i can never remember) and the silver tops are the other way round
so technically you can use them, as long as its with the right length pistons to match, as said
