???? HOW MUCH BHP ????
Ive just bought myself a s2rs and its had a bit of engine work done any ideas hw much bhp it could be putting out with the followng spec.....
2 litre zetec bottom end
mahle low compression pistons
ported/flowed head
uprated kent cam
vernier pulley
full exhaust system 3"bore.. 4" tailpipe
hybrid cossie t3 turbo holding 17/18psi....
thedrive home had me spinning the wheels in 4th..
. but it was fcukin wet
..cheers all...p.p
ported/flowed head
uprated kent cam
vernier pulley
..cheers all...p.p
also ive got a standard airbox with a kn element, is it worth getting a kn cone filter?, and its not running a dump valve is that a bad thing?, would putting a baileys piston style one be a worthwhile mod? cheers
Originally Posted by sufsRS
cone filters are good when on the move but soak in hot air when idling so make sure its getting cool air, and theirs no need for a pump valve we hate them
If its 18 PSI on low, dont turn it up - otherwise your rs ownership stage of your life will come to an expensive end, 2 Stage boost controllers usually half the PSI, so if your running 18 psi on low, high will be 36 psi which i dont think works out
for example, my low boost is 13 psi, and my high is 26 - 27, but sometimes on a nice cold morning or night, it will boost 30 psi - now thats fun !
