interior light, trip computer, cigarette lighter stoped wkin
ciggy lighter interior light and trip computer has stoped working on my S2
i have checked all the fuses in the fuse box and all looked ok so fuck knows
i thought i would post somthing up in here to see if anyone has come across this problem before
i need to use the ciggy lighter for my 240v inverter to power my lappy because im geting the omex upgraded tomorrow/tonight to omex 600 and will need lots of mapping again!
so in a few days i will post a graph of what a zetec running a bar at 9.5:1 cr is like
roll on the traction control launch control knock sensor.. etc etc
just got the loom 50% installed with the omex 500 still in place and running so i can still drive around
i have decided to have the inverter conected to the battery through the new hole i made in the bulk head using a relay so it goes on and off with the ignition
i have also discoverd that this omex 600 controlls the radiator fans and the fuel pump
and while flicking through the book i can teach it what gear im in and map the boost for that particular gear
and can controll an idle controll valve whitch i presume has somthing to with anti lag
so im going to need shit loads of relays
and seems like mapping/connecting all thease gadgets is going to be a right load of fun
i'm having fun anyway
and seems like mapping/connecting all thease gadgets is going to be a right load of funi'm having fun anyway
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
