Fule Pump
hi on my rst when i flick the key i cant hear the fule pump prime but onec you turn the car off u can hear the pump go off
........anyone got any ideas
Is it broken has the relay failed?
plesae let me know what u think?
If its not priming for a second when you initially flick the key then it sounds like the prime function in the relay isnt working. As for the running problem this isnt related to the relay i wouldnt of thought, if the relay was completely fucked it wouldn't run
SMILER258
Sep 28, 2015 09:04 AM
