Splutters on a sapph
Old Jan 2, 2006 | 09:30 PM
G2 FSR's Avatar
G2 FSR
Default Splutters on a sapph
Having problems with spluttering when i put my foot down. Now i believe its the 3 plugs or so that run along the back of the engine. Now ive cleaned them and so on, but still getting the problem......any suggestion!
Old Jan 2, 2006 | 09:43 PM
whitecossie's Avatar
whitecossie
could try new plugs , then phase sensor as the insulation burns off and shorts out i think thats the right name for the sensor in the dizzy ,
Old Jan 2, 2006 | 09:51 PM
cossieguy's Avatar
cossieguy
My 3 door started doing that, i ended up taking it to power engineering and it turned out to be the coil.
Old Jan 2, 2006 | 11:06 PM
Reece's Avatar
Reece
is it splutterin or banging cos mine was banding and stuff and it turned out it was over boostin and by this time id nakered the head gasket
Old Jan 3, 2006 | 08:32 AM
XR4Timan's Avatar
XR4Timan
phase sensor/coil - try those first
Old Jan 3, 2006 | 05:16 PM
G2 FSR's Avatar
G2 FSR
Its spluttering, not had any bangs yet!! When i first cleaned those sensors it had made a difference, but now its re-apeared. So should i try changing the coil??
Old Jan 3, 2006 | 07:35 PM
Harris.'s Avatar
Harris.
Yeah go for the coil as mine was the same,i got a new coil for Ł10
Old Jan 3, 2006 | 07:40 PM
G2 FSR's Avatar
G2 FSR
Thanks fella will give it a go! Is it worth me going for a group a coil??
Old Jan 3, 2006 | 07:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Get a group a coil m8 only 30-40 quid.
Old Jan 3, 2006 | 07:46 PM
G2 FSR's Avatar
G2 FSR
Old Jan 3, 2006 | 07:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Oh yeah and clean your crank sensor too.
Old Jan 4, 2006 | 01:09 AM
XR4Timan's Avatar
XR4Timan
Group A coil needs new connectors fitting. Just try a regular coil for now.
The phase sensor is in your dizzy. It's like a half-moon magnet with two wires running from it to the top of the cap, ending in a connector. Usually the wires's insulation flake off, and they touch each other and cause these symptoms as well.
Old Jan 4, 2006 | 01:59 AM
Reece's Avatar
Reece
also my bottom pully came loose so wasnt lined up wit the sensor properly
timsrs
Nov 13, 2018 11:48 AM
DavidK
Sep 27, 2015 02:55 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
