bike carbs on zetec
Old Jan 2, 2006 | 09:28 PM
tonyturbo's Avatar
tonyturbo
Default bike carbs on zetec
may be purchasing a RS1800 fiesta this week with a 2ltr zetec fitted. i thought about turboing it but like the idea of the bike carbs which seems to be getting popular now.
all fabrication work will be done locally.
what happens to the existing ecu etc?
is it still needed for spark etc?
i aint got a clue with this kinda thing!
where is best bit to get bike carb? roughly how much? what kind etc?
Old Jan 2, 2006 | 09:30 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Are you sure you mean Carbs and not just the throttle bodies from a Bike?
Old Jan 2, 2006 | 09:44 PM
tonyturbo's Avatar
tonyturbo
these!
Old Jan 2, 2006 | 09:49 PM
The Youth.'s Avatar
The Youth.
there is a garage called bogg brothers (father +2 sons) near scarborough who have done this conversion loads of times, they will be the best peple to speak to.
Bogg Bros Ltd
01944 738234
The Garage
Malton, YO17 8TG
just found the number
steve
Old Jan 2, 2006 | 09:50 PM
MAD EVO 4's Avatar
MAD EVO 4
Pic looks very nice, could be an option for my engine
Old Jan 2, 2006 | 09:54 PM
R4N SS's Avatar
R4N SS
didnt fudgeass do something similar
Old Jan 3, 2006 | 07:29 AM
Markb_s1's Avatar
Markb_s1
yes he did.. or get on to turbosport.co.uk - there's a whole section on zetecs including a guy called RChambers who did exactly what you're thinking of in his mk2 escort.
Old Jan 3, 2006 | 09:24 AM
Arfur's Avatar
Arfur
I'm sure Fudgeass will enlighten you when he eventually turns up for work.
Old Jan 3, 2006 | 09:44 AM
It's Czech Mate's Avatar
It's Czech Mate
Bogg Bros did the one in the picture. Its an RS1600i so the ecu and coils were retained for ignition. Fueling isnt done through ECU anyway on a 16i. They are carbs too not TB's Didnt Fudgeass use TB's, these are a different kettle of fish and much more complicated as they require management that can run from a TPS
Old Jan 3, 2006 | 11:13 AM
Garage19's Avatar
Garage19
Bike carbs and bike throttle bodies are two different things.
If you check out this months Fast Ford there is a 3dr with a 2.1 pinto running 38mm gsxr carbs. The manifold is home made and the carbs are spaced to suit.
You must bear in mind that these carbs are CV and therefore the bore is straight through. A 45 side draught will in fact run a 34 or 36mm choke.
I had helped setup the 3dr and have to say that the bike carbs are very easy to tune compaired to 45s. More like hi tech SUs.
I used a seperate dizzyless, coilpack mappable ignition on the 3dr.
Old Jan 3, 2006 | 11:22 AM
Garage19's Avatar
Garage19
Ok, found some pictures of from when we were fitting the carbs.
Old Jan 3, 2006 | 11:40 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
the cheek! you knew what i was doing lol!
anyway - carbs - no, throttle bodies - yes
i use 45mm t/bs from a GSXR 750 cossie injectors and SECS S8 management.
was pushing around 200bhp!
and some of the bodge, i mean build lol
spacers for them to fit zetec inlet
spacers for throttle linkage
longer tubes from modified fuel rail
blank injectors to be used as idle bypass
basic assembly
modded inlet manifold lol
modded fuel rail just to allow injectors to fit
assembled with air box
on engine with fuel rail and injectors
File Type: jpg
Old Jan 3, 2006 | 01:12 PM
tonyturbo's Avatar
tonyturbo
i like lots! bit more money involved in the conversion than i thought. doesnt look like she's gonna let me buy the car anyway as she wants the drive paved and a car would just be a waste of money. she must b sick of getting her feet dirty when she gets of her broomstick!!!!!!!!!!!!!!!!!!!
Old Jan 3, 2006 | 01:14 PM
MAD EVO 4's Avatar
MAD EVO 4
Old Jan 3, 2006 | 01:30 PM
It's Czech Mate
I think Bogg Bros will do the above carb conversion for about Ł750 fitted and set up.
Old Feb 22, 2009 | 04:59 PM
Shakey Jake's Avatar
Shakey Jake
I have just sold my mk2 fiesta in which i done an r6 bike carb convertion.
I will soon be able to supply a zetec inlet manifold to accomadate carbs...
A set of re jetted ( not drilled ) carbs with internal work as mine did by Jekyl and Hyde
And if needed megajolt management running load for map.
Fitting will be avaliable.
Live maps also avaliable through Jekyl and Hyde.
May possibly do manifolds for cvh if there is enough interest.
But i will be able to supply and fit all the above cheaper than bogg brothers INCLUDING management.
Email bikebodies@hotmail.com for info.
Old Feb 22, 2009 | 05:21 PM
Stu @ Claims Care Centre's Avatar
Compensation Specialist
i have some throttle bodies on a bogg bros manifold in non rs items for sale! and cheap.
Old Feb 22, 2009 | 06:00 PM
Garage19's Avatar
Garage19
Crikey... thread from the dead!
Shakey Jake the PF police are going to kick your arse for trading if you are not carefule!!
Old Feb 22, 2009 | 07:10 PM
Shakey Jake
Lol Read carfully mate.... say may be.
Am i going to pay to trade on here if it isnot all set up yet.... NO lol
Old Feb 22, 2009 | 07:11 PM
Shakey Jake
What bodies and how much mate.
Old Feb 22, 2009 | 07:16 PM
Mr RS500's Avatar
Mr RS500
Boggy"s will sort you out
What a great family they are , always go out of there way to help people out , and the 2 brothers Steve and Pete are great at what they do , and there Father , Dave , well you wont find a man on the planet that can set carbs up like him
They will be fitting bike carbs to my N/A cossie engine ( when i get round to building it ) lol
There about 10 mins from my house so if i can help in any way please ask
Paul
Old Feb 22, 2009 | 07:21 PM
there gsxr1000 ones and Ł350 posted (manifolds nearly that)
Old Feb 22, 2009 | 07:24 PM
Shakey Jake
Paul
Beg to differ when they charge Ł80 just to drill jets out on bike carbs and say thats good enough to run on a car.
My carbs had a hell of alot more done to them and the difference was fooking untrue.
Do like their manifolds though although the angle of the zetec manifold they do is too flat imo and mega expensive to usual people at Ł200.
Old Feb 22, 2009 | 07:39 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
" quote" Do like their manifolds though although the angle of the zetec manifold they do is too flat imo and mega expensive to usual people at Ł200. "quote"
i was just thinking that manifold was the wrong angle .
Old Feb 22, 2009 | 07:48 PM
Garage19's Avatar
Garage19
The manifold above is for throttles bodies. It doesn't matter hat angle they are at.
Most people make the manifolds too flat. Modern bike carbs are usually designed to run at 45 deg or more.
Old Feb 22, 2009 | 07:51 PM
Shakey Jake
Thats the one..... mine had an angle of 40. Ran superb.
Old Feb 22, 2009 | 08:09 PM
Lloyd's Avatar
Lloyd
so what will work better? for throttle bodies.
1. manifold as above,injectors pointing at the opposite side of the manifold and at 90 deg to the head,so the air has to flow around that 90 deg
or
2, standard st170 injector manifold,with the injector pointing at the back of the valves,inlet manifold at 45deg to the head,air flow pointing at the back of the valves.
Old Feb 22, 2009 | 08:19 PM
Shakey Jake
or
Either will work mate.... but ford didn't spend millions designing that manifold for nothing.
There are alot of different ways people use throttle bodies mate and i would not like to say which was best.
Old Feb 22, 2009 | 09:56 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
stu, thats not a bad price mate, i sold my complete setup for Ł600 lol, but the airbox did cost Ł105 from rainbird
Old Feb 22, 2009 | 10:17 PM
just sold them on turbosport and my st170 engine.
someone got a good deal
Old Feb 22, 2009 | 10:48 PM
Shakey Jake
Make a nice package that.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
