s1 and s2 turbo's
Jan 2, 2006 | 07:05 PM
s1 and s2 turbo's
Will a S1 T3 Turbo fit a S2?
Thanks,
Jim.
Jan 2, 2006 | 07:06 PM
dont think s1s are water cooled, other than that the same i think
Jan 2, 2006 | 07:14 PM
yep as above but you could always just block the pipe
Jan 2, 2006 | 07:15 PM
I need some more help on this subject please.
Thanks for your help rich just need to no for sure.
Jim
Jan 2, 2006 | 07:21 PM
yeah fits just the same just block off the top water pipe that goes into the turbo and the 1 where it goes bk into the rad
Jan 2, 2006 | 07:24 PM
So it will be fine to use.
Jim
Jan 2, 2006 | 07:26 PM
yes its just not water cooled thats all and the s2 is block up the pipes and your away
Jan 2, 2006 | 07:28 PM
thanks mate...
Jim
Jan 2, 2006 | 07:39 PM
What is the max bhp of this turbo?
Jim
Jan 2, 2006 | 07:40 PM
Jan 2, 2006 | 07:44 PM
Jan 2, 2006 | 07:48 PM
dont no prob 170-190 bhp about 15-17psi
Jan 2, 2006 | 07:52 PM
arr it will be no good then...
I need a turbo that will run up2 280bhp.
What turbo will i need ?
got the bottom end sorted.
Jim
Jan 2, 2006 | 08:03 PM
stage three hybrib t3,
t34 hybrid turbo
hybrid 4x4 cossie t3
gt28 roller bearing turbo with external waste gate (i wish i had 10
a t28 of a nissan 200sx (will need a screamer pipe with this turbo)
options are endless, depends what boost you wanna run and how much lag you can put up with?
Jan 3, 2006 | 06:42 AM
im using a stage 3 T34 off a 2wd cossie good 4 400bhp
u need to modify the exhaust down pipe like this
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
