Stage 1,2,3 turbos
Old Jan 2, 2006 | 01:59 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Stage 1,2,3 turbos
ERST T3's
Standard and all 3 stages what size housings they come with? and internals
cheers..Radders
Old Jan 2, 2006 | 02:46 PM
SafeChav's Avatar
SafeChav
Ive got a stage 3, and thats got a cossie compressor in a modified T3 housing, 360 bearing, 7 degree cut back on the blades and a 48 exhaust housing.
Duno if this helps, if not i guess its just tough luck
Old Jan 2, 2006 | 05:49 PM
ballin's Avatar
ballin
stg1 : STD EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, UPRATED THRUST BEARING (NOT 360 deg) -31 ACTUATOR
stg2 : STD EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, 360 deg THRUST BEARING, -31 ACTUATOR
stg3 : LARGER EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, 360 deg THRUST BEARING, -31 ACTUATOR
according to burtons! stg3 is .48 housing
Old Jan 2, 2006 | 06:31 PM
essexrsturbo's Avatar
essexrsturbo
all T3's will come with a .42 A/R housing.. you can put a .48 exhaust housing on any T3
Old Jan 2, 2006 | 07:43 PM
Rick's Avatar
Rick
I'll ignore the shit thats just been spouted
Stage 1 - Usually one of two configurations. Either a std turbo bit with uprated seals and bearing, or std seal and bearing with a larger compressor - nearly always the former.
Stage 2 - 360 thrust bearing, staggered gap oil seal, and 55 trim compressor wheel with a std rear end.
Stage 3 - as above, but sometimes with a 60 trim wheel and always a 48 rear end
Old Jan 2, 2006 | 07:47 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
Originally Posted by Rick
Stage 3 - always a 48 rear end
unless specified otherwise
Old Jan 2, 2006 | 07:58 PM
Rick's Avatar
Rick
lo, then it's not a stage 3
Old Jan 2, 2006 | 08:08 PM
Chrissy_bwoy
true but what would ya call it then?
as mine has a .63 rear end, stg3+ or stg 4 or 5?
Old Jan 2, 2006 | 08:51 PM
essexrsturbo
pmsl @ ppl that fink that can judge a turbo on "Stages"
Old Jan 2, 2006 | 08:58 PM
Chrissy_bwoy
y not most turbo manufacturers base them on stages and variations there of
Old Jan 2, 2006 | 09:22 PM
Rick's Avatar
Rick
u wouldnt call it anything as such. The stg 1-3 are pretty universal, as they work well for most people. There a loads of different combo's of turbo bits, so it's to state the full spec when u are talking about a specific need. A t3 with a 63 back is a a laggy turbo with a small powerband - the smaller back pressure is pretty redundant as the compressor is out of it's efficiency zone.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
