Removing a bottom end/Gearbox, Got a prob tho..
Old Jan 2, 2006 | 08:43 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Removing a bottom end/Gearbox, Got a prob tho..
Mines been back in for a while, But gotta come back out,Thing is, I cant get the front wheels off as I cant find my locking wheel nut ANYWHERE
So I cant take my drive shafts out, Is there another way to get my bottom end/Gearbox out again
Needs to be done sharpish really, So i dont mind bodging anything/breaking anything
Please help! LOL
Radders
Old Jan 2, 2006 | 08:52 AM
nigel b's Avatar
nigel b
take the driveshaft out from the gearbox instead
Old Jan 2, 2006 | 08:53 AM
ballin's Avatar
ballin
you can leave them attached to the hub quite easily mate.....bit more of a pain to work around them but its very possible; although with the wheels on I'm still not sure if you would be able to get enough access?
basically do it as you would normally, undo trackrod end balljoint, arb and lower arm balljoint.
if you can get at all those with the wheel on then you should be fine, pull em straight out the box and tie the driveshaft up so you dont knackers the joints..
good luck matey
Old Jan 2, 2006 | 09:01 AM
Tim's Avatar
Tim
Always leave my wheels on anyway,its easyier to pull shafts out with em on
Old Jan 2, 2006 | 09:11 AM
Charlie Chalk
Unknown.
Cheers All
Will let you know how I get on
Old Jan 2, 2006 | 12:58 PM
DazC's Avatar
DazC
Do you need to take the box out? You could leave the box in and just remove the bottom end.
Or just pop the ball joints out and leave the shaft in the hub and just pop it out of the box at the other end...
Old Jan 2, 2006 | 01:03 PM
Charlie Chalk
Unknown.
The cars going away to have the engine bay seam stitched and the cage welded in, so yeah, its gotta be empty
Old Jan 2, 2006 | 01:44 PM
DazC's Avatar
DazC
Still a piece of piss though. Stop fucking about!
Old Jan 2, 2006 | 01:47 PM
Charlie Chalk
Unknown.
Pah.. Im new to this
Old Jan 2, 2006 | 02:08 PM
bud-weis's Avatar
bud-weis
Football Cwazy
any pics ?
Old Jan 2, 2006 | 02:16 PM
Charlie Chalk
Unknown.
Of... The cage and stuff.There will be in time
Old Jan 2, 2006 | 02:17 PM
Red16's Avatar
Red16
pics or stfu rad
Old Jan 2, 2006 | 02:18 PM
Charlie Chalk
Unknown.
Bollocks ben
You know the score
Old Jan 2, 2006 | 02:33 PM
Red16's Avatar
Red16
i know, just pulling your leg freddy
Old Jan 2, 2006 | 02:34 PM
Charlie Chalk
Unknown.
Thats Mr.Rad to you
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
