hearts and diamonds
i have got pics of pink hearts and blue diamonds on my ecu, can anyone shed some light on this, also i found what looks like a fuel regulator below the fuel metering unit that has a bit for a vacuum pipe but theres no pipe,!!!!!! is there supposed to be a vacuum pipe on this if so where does it go to
U say your ecu has coloured hearts/diamonds on it??
pre 90 spec ECU's have coloured sqaures, 90 spec have heart, diamond, hash symbols printed black on the front.
Your fuel pressure regulator, a standard car doesnt have one, its sprung loaded inside to give a preset pressure, i believe tuning companies however do run a pipe to this to increase fuel pressure at high boost.
I'd speak to a tuner before you try it however (if you are going to)
Originally Posted by addiction
on the s2 most of the ecu's with the coloured squares on have a knock sensor!!
a series 1 does not have a knock sensor
Originally Posted by KSA-Cossie
Early s2's didn't have em either m8.
Vacuman
16
Sep 3, 2015 06:26 AM
McPikie
Sep 2, 2004 12:31 PM
