water leaking?
i fitted some speakers in my van the other day in the foot wells but when i took the speaker pod out i noticed water it wasnt massivly wet but it had been leaking, any idea where this could have come from? is it a common thing?
SOUNDS HORRIBLE,BUT TASTE THE WATER.IF ITS SWEET THEN YOUR HEATER MATRIX IS LEEKING.IF NOT ITS PROBABLY RAIN WATER AND YOU HAVE A HOLE SOMEWHERE OR PERISHED SEAL.GET YA TORCH OUT.
usual suspects are:
fuse box
battery tray
bottom corners of windscreen
heater matrix
seal between the door and A pillar (one wires run through for electrics)
wing mirror seals may be perished but not very common.
fuse box
battery tray
heater matrix
lift the windscreen seal up, either that or the black sticky sttuff under the seal could of went brittle and leaked.
get someone to hold a hose all over that area whilst you stick your head in the wet area and look for leaks.
good luck
good luck
Mark RS
Oct 12, 2015 06:01 AM
