Alloy braces arent too bad. I havnt used a rear brace yet but just bought 1 off someone on here so should tighten the back end up. I always look in the sales adds on here before buying a new brace from anywhere.
Speak to Lee at Fusion see what he can do for you he's a user on here as well so fairly easy to track him down
all of lee's work is the bollocks! just sent my fuel pump off to him for -6 connectors to be welded on, as for strut braces steel are stiffer than alloy but there all good.
On the Fiesta Id recommend using OMP, the sparco brace is too difficult to fit properly. Th eOMP you can drill straight down into the top of the inner wing/turret section where as with the sparco its from the side and u cant get all the holes. Had to drop my front shockers out to put it in properly!
