strut braces
whats good ones for fiesta or are they all much the same
Don't think there is too much between them to be honest mate. Do you want an alloy or a steel one?
Theres not much difference in them but as a matter of prefrerence i use OMP
are there advantages in having steel or alloy
Alloy looks a bit nicer but it's there to do a job. Never gone wrong with an OMP one in any of the cars we've fitted them to. Nicely priced as well :DD:
sounds good might just have to order one when i get home :top: . do rear braces make much difrence
Never had one TBH so can't say
One bit of advice i'd always heard was don't use the self tapping screws supplied to fit the brqce - they easily become loose after driving.
Yep drill the turret and then nut and bolt it with good quality fastners :top:
is there one thats adjustable for the fiesta ??
if not might have a word with less at fusion as he has made my mates strut brace for his mk6 fiesta and they look cool |
Lee's workmanship is 100% spot bollock on. I've seen quite a few of the bits he's done and they have all been superb :top:
Are the Fusion ones more for show?
There is a bloke on ebay called strut bracer that is pretty good with OMP steel braces. |
Alloy braces arent too bad. I havnt used a rear brace yet but just bought 1 off someone on here so should tighten the back end up. I always look in the sales adds on here before buying a new brace from anywhere.
Speak to Lee at Fusion see what he can do for you he's a user on here as well so fairly easy to track him down |
all of lee's work is the bollocks! just sent my fuel pump off to him for -6 connectors to be welded on, as for strut braces steel are stiffer than alloy but there all good. :top:
On the Fiesta Id recommend using OMP, the sparco brace is too difficult to fit properly. Th eOMP you can drill straight down into the top of the inner wing/turret section where as with the sparco its from the side and u cant get all the holes. Had to drop my front shockers out to put it in properly!
© 2024 MH Sub I, LLC dba Internet Brands
