warning light??
Old Dec 31, 2005 | 02:16 AM
escortlad's Avatar
escortlad
Default warning light??
when im drivin along and brake my handbrake warning light comes on and off and also does do it other times but only comes on for about 3seconds at the most at anytime!
Anyone had this or know why it is?
Old Dec 31, 2005 | 02:41 AM
NUTS RuS's Avatar
NUTS RuS
If your brake fluid reservoir bottle has a sensor it could be the level is getting low because the pistons are extending due to pad and disc wear.
Old Dec 31, 2005 | 10:06 AM
JesseT's Avatar
JesseT
Yep, that's it for sure. When you check the level, remember that the light comes on as soon as the level isn't at max anymore.
Old Dec 31, 2005 | 03:14 PM
SafeChav's Avatar
SafeChav
As above, for definate!
First time this ever happened to me years ago i couldnt work it out, it would only do it on this on road which is down hill, and cos i was always wanking down it i had to brake hard.
Felt silly when i realised what it was
Old Dec 31, 2005 | 11:58 PM
escortlad's Avatar
escortlad
cheers,i had that in mind really but wasnt sure,i have some spare drilled and grooved disk to fit but need to stop bein tight and buy some pads!
Old Jan 2, 2006 | 01:02 PM
adamS2RST's Avatar
adamS2RST
Could also be a problem with the abs system
Old Jan 2, 2006 | 01:14 PM
SafeChav's Avatar
SafeChav
Does the ABS connect up to the handbrake light? I thought ABS had its own warning light?
Old Jan 2, 2006 | 01:16 PM
adamS2RST's Avatar
adamS2RST
You should notice the abs light come on when the handbrake is applied....tbh, i'm not certain it is, just know of someone having the problem before.
Old Jan 2, 2006 | 01:17 PM
SafeChav's Avatar
SafeChav
I dont have ABS so im none the wiser if it ABS. I dont even want to venture into the mechanical ABS after all ive read and heard about it, im considering electronic ABS though
Old Jan 2, 2006 | 01:22 PM
adamS2RST's Avatar
adamS2RST
I don't have ABS anymore either
Old Jan 2, 2006 | 01:23 PM
SafeChav's Avatar
SafeChav
For obvious reasons i presume?
Old Jan 2, 2006 | 01:25 PM
adamS2RST's Avatar
adamS2RST
Yes. Most are aware of the abs on these cars being errr not very good. Having upgrading my brakes and having discs all round with no abs was the best mod I have done to my car
Old Jan 2, 2006 | 01:27 PM
SafeChav's Avatar
SafeChav
I thought as much. Ive had people say the ABS has actually made the brakes fail the MOT tests before, very primitive from my understanding of it. I'm looking into ABS off something more modern, dont know whether i actually will or not yet. All extra weight at the end of the day and being a cabriolet it was shitloads as it is
Old Jan 2, 2006 | 07:30 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
The ABS is the orange "skidding car! light..but if one of the ABS belts breaks, then the h/brake light comes on as a warning/indication that there is a problem with the brakes.
But as you have no ABS fitted...see the top posts I think: fluid level.
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Sep 28, 2015 10:05 AM
