Some question's.
Old Jul 15, 2004 | 05:42 PM
Alloy's Avatar
Alloy
Default Some question's.
Hello all, i'm new to PassionFord as you will probably notice.
Anyway, i'll kick off my first post by asking some question's.
I seen these term's written in FastFord magazine, the term's are:
torque steer.
wire ringed block.
Would someone care to explain them to me please? I'm still learning a great deal by reading FastFord, but I couldn't find anything about those term's above so i've come here.
Thank's in advance, Gareth.
Old Jul 15, 2004 | 06:07 PM
kay2's Avatar
kay2
torque steer generally comes from having high power delivered through the front wheels, generally its worse when you have different length drive shafts, its almost as if the car squirms from side to side under hard acceleration, gives you great forearms
Old Jul 15, 2004 | 06:08 PM
RANJ's Avatar
RANJ
and u wont learn alot by reading fast ford either
Old Jul 15, 2004 | 06:13 PM
Ima-Racing500's Avatar
Ima-Racing500
...or any of Dingys posts...ROFL
Old Jul 15, 2004 | 06:15 PM
Billabong's Avatar
Billabong
Wire ringing is where a groove is cut into the top face of the block, around the bores. A wire ring is then inserted which bites into the head gasket, giving a better seal if done correctly.
It's not so often done now though, with the advent of multi layer steel headgaskets.
Old Jul 15, 2004 | 06:22 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
apso spot on philys pmsl
Old Jul 15, 2004 | 07:44 PM
Alloy's Avatar
Alloy
That's a great help guy's, thank's again.
Why do you think FastFord won't learn me anything RANJ?
I'm not doubting you don't learn anything, I just disagree with you and personally I find it helpful. I have been reading it for about 4 month's and I have learned a good deal from it.
Old Jul 15, 2004 | 07:48 PM
Paul_RS's Avatar
Paul_RS
i think fast ford is pretty helpful when it comes down t explaining stuff. i'd also like to know what exactly is involved in wire ringing a block. i know it has something to do with making it stronger, but how is this achieved?
Old Jul 15, 2004 | 08:54 PM
Billabong's Avatar
Billabong
I've told you above , it doesn't make the block stronger, it helps to make a better seal between the head gasket & block.
Old Jul 15, 2004 | 09:04 PM
Lee Reynolds's Avatar
Lee Reynolds
So..................................How does Wire ringing work then?
Old Jul 15, 2004 | 09:08 PM
RANJ's Avatar
RANJ
ive virtually read it from when it first came out
some bits are useful but some aaint imo
Old Jul 15, 2004 | 09:45 PM
Paul_RS's Avatar
Paul_RS
@ billabong sorry mate, my eyes must have been on a smoke break when i tried to read the thread!
Old Jul 15, 2004 | 09:50 PM
Shings's Avatar
Shings
If u like Body kits its a great read... yay!
Old Jul 15, 2004 | 09:53 PM
Alloy's Avatar
Alloy
That's fair enough RANJ, suppose you're right in a way, otherwise I would not have come on here asking these type's of question's.
I had an idea of what torque steer was, but wire ringing just plain baffled me.
LOL, one thing i've learned from being on forum's is to read every reply in a post, made a fool out of myself plenty of times from not doing so!
Old Jul 15, 2004 | 09:57 PM
TrickyDicky's Avatar
TrickyDicky
Ranj
if youve read it since it first come out, you will have probably noticed how its changed from a proper tuning mag ie flowed heads etc and cams to ice installs and bodykits, i used to have it in the early nineties and found a few in the loft about a year back and bought a new mag off the shelf-i thought what a pile of shite!
Tricky
Old Jul 15, 2004 | 10:00 PM
Shings's Avatar
Shings
SHOCK NEWS FLASH
Tricky brought somet- and it wasn;t part of a deal
SHOCK NEWS FLASH 2
Tricky brought somet fucking useless
J
Old Jul 15, 2004 | 10:08 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Thats all well and good Bill.
But
Whats wire ringing
Old Jul 15, 2004 | 10:11 PM
Alloy's Avatar
Alloy
Look through the replies and you will find out what wire ringing is!
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
