ZVH advice
Old Dec 29, 2005 | 05:37 PM
Matt_B's Avatar
Matt_B
Default ZVH advice
How much work is invloved in building a zvh engine?
I've got a stage 2 cvh head and stage 2 turbo in the garage so i was thinking of gettin a bottom end and just building a new engine, then i thought of the zetec bottom end instead
Just wonderd what is involved
Old Dec 29, 2005 | 06:12 PM
Robin's Avatar
Robin
http://www.quantums.info/zvh.htm
there u go chap
Old Dec 29, 2005 | 06:14 PM
Oranoco's Avatar
Oranoco
You will need to either skim the standard pistons or get a set of LET Vauxhall pistons and have them modded to fit the Zetec rods to drop the compression. You will also need a plate to enable the use of the CVH water pump and will also need the 1.3 CVH cam belt tensioner.
Ian Howell of Fiesta Frenzy/Area Six fame is the Daddy with these engines
Old Dec 29, 2005 | 06:20 PM
Ezzy Danny's Avatar
Ezzy Danny
pritty easy mate if ya good with engines the above link to quantums it wot i did mine off and it runs perfect everyday!
Matt_B's Avatar
Matt_B
So not really a big jor to do? do you think it is worth it to change to a zetec bottom end or should i stay cvh???
Old Dec 29, 2005 | 06:33 PM
Oranoco's Avatar
Oranoco
I'm a big CVH fan and will be retaining them, in both my RST's. It's a personal thing. Do some research and see whether it will suit what you want from the car.
Have to admit I did look at going ZVH on my FRST but decided to stick CVH
Old Dec 29, 2005 | 06:44 PM
Matt_B's Avatar
Matt_B
how much do you think i would be looking at for a good 1.6 bottom end if i wanted to stick to the cvh route? just thought it is daft to bolt a nice head and turbo to a batterd bottom end thats all
Old Dec 29, 2005 | 06:50 PM
Oranoco's Avatar
Oranoco
My bottom end cost me £2200 to have it dropped out worked over and then put back in again.
Can't say on the Fiesta as it's on my drive at the mo and hasn't moved since the end of November
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
