Efi loom
Dec 29, 2005 | 01:06 PM
Efi loom
Can i use an efi loom from a mk4 XR3i to convert to efi?
Dec 29, 2005 | 01:41 PM
Any one know i could do with knowing this aswell????
Dec 29, 2005 | 03:22 PM
Obvio
I presume you mean to convert a MK4 MFI to EFI?
Dec 29, 2005 | 03:33 PM
Dec 29, 2005 | 03:35 PM
Of course!
Its the same car!
may be a couple of areas that cause a few problems, for instance the petrol tank sender/fuel pump plugs......
but if your going to go EFI thats probably the most reliable way to do it.
Dec 29, 2005 | 03:36 PM
nice one for that cheers
Dec 29, 2005 | 03:48 PM
No problem mate
dont forget the EFI engine also has a couple of differences incase you are planning to use your MFI lump?
Dec 29, 2005 | 06:12 PM
Do you not just use one of Jano's Converter things? And can you use any ecu? ie OFAC, OFAB or cossie with the XR3i loom?
Dec 29, 2005 | 07:00 PM
Quote:
Not familiar with Jano's "converter thing" as u specifically put it
OFAB/OFAC/Cossie ECU on an XR3i ......GOD NO
muz
Sep 30, 2015 08:29 AM
liamT74
Sep 23, 2015 10:24 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
