Is Karl norris the king of tuning
Originally Posted by Stoo
Everyone will have different views
It's like asking whats the best colour for ERST
And king of tuning is a garage in saltcoats called REG BUILDS
i went to 3 different places to get my van sorted, but karl was the one that sussed it and got it running sweet ..................go figure, and yes grey is the best colour, LOL
I dont doubt he is good......
But grey is the best colour
Must be the reason you weant a colour change then
Originally Posted by gus
grey might be the best but i always thought white was the fastest colour car to have
I guess when it comes to the escorts his cars ie setup etc were
2nd and 3rd fastest topspeed on standard ratios,fastest escort to 60,fastest escort to 100 and fastest escort 1/4 all timed by proper gear from PFord says enought to me .
All at the moment lol as cars get better and faster all the time.
Guess im biased lol.
AVE IT.
Wonder what next year will bring what with jamie's monster and a few others.
AVE IT.
I heared harvey gibbs is good, he tuned the engine i got in my car now, and its solid as a rock - been boosting 26 psi for a while now and not a single engine problem since i bought the car, Only problem ive had is the metering unit which has just packed in
Full engine spec for those interested, And Harvey Gibbs is based in Peterbrough ( Spelt wrong probably ) i have his number etched on a plate under my bonnet if u want it.
ENGINE: 250 Bhp // 248 Lbs Torque @ 26 PSI
: Tunned and preped by SCS and Harvey Gibbs
: 7:6.1 compression ratio using Mahle pistons
: Mildly ported head using standard cam
: K+N panel filter
: Modified fuel system ( for increased fuel pressure when on WOT only )
: Hybrid T3 turbo 360 degree thrust bearing
: 48 exhaust housing
: 60 trim compressor
: 31 actuator
: Ahmed Bayjoo open chip with revised ignition curve and 3 degrees advance
: GRS EVO 3 intercooler
: Two Kenlowe 2000 blow fans
: Samco hoses
: Scorpion stainless exhaust system
: Felpro Group A Headgasket
: ARP Strengthened Head bolts
: Iridium Spark Plugs
: Ford Motorsport HT Leads
: 2 Stage boost controller // 13 Psi or 26 Psi
TRANSMISSION
: Geartorque £1000 Gearbox with 1 years warrenty
: Enlarged IB5 mainshaft and bearings
: Uprated baulk rings
: Top speed = 157 @ 6250 in fifth
: AP Paddle Clutch
: B&M Quickshift Leaver
SUSPENSION
: Lowered 40mm at the front 40mm at the back
: KONI top adjustable dampers
: Powerflex bushes
: OMP front strut brace
: Custom made rear strut brace
BRAKES
: Wilwood `billet` aluminium 4 pot calipers
: 285mm red dot discs
: Wilwood poly-D race pads
: Braided Brake Lines
: New Copper rear brake lines
WHEELS & TYRES
: 7 x 17" Team Dynamics Monza alloys in Anthracite
: BF goodrich profiler G tyres on rear
: Falken Tyres on front with good tread
EXTERIOR
: Recent full respray and body restoration
: Smoked Rear lights
: Smoked side indicators
: Black Nurburgring Stickers on Rear and side
: RS Badges under indicators
: Underneath just been re-undersealed
INTERIOR
: Mint RS 3 spoke steering wheel
: Sony CD Player
: Sony 13cm Door speakers
: Vibe 300w 6x9's
: Vibe CBR120 Sub Enclosure
: Stealth Shelf
: Kicker Competition Amp
: Boost Control switch
: Fan Overide switch
: Flamer Kit switch
: Fire Extinguisher
: 88 Spec interior, Mint no scuffs or tears atall
: Cat 2 Immobiliser
: K+N panel filter
: 31 actuator
: Samco hoses
TRANSMISSION
: AP Paddle Clutch
SUSPENSION
: Powerflex bushes
BRAKES
WHEELS & TYRES
EXTERIOR
INTERIOR
: Sony CD Player
: Vibe 300w 6x9's
: Stealth Shelf
: Flamer Kit switch
: Fire Extinguisher
: Cat 2 Immobiliser
i know S1 Lee on here swears by Karl Norris hes been there a couple of times and had excellent results
I May be taking mine there when i have the cash
you know how it is
What are your opinions of PJ Motorsport ??
you know how it is
i know ill be spending time and money at nms in 06 , with karl the customer service is superb, he goes above and beyond what most tuners call a good service , hes thorough and honest , what more could you ask for ?
Originally Posted by Damienholmes
whats your full engine spec mate if you dont mind, could you pm it to me ?
Engine;
1600cc 8v CVH
Farndon H section Steel Rods
Custom made Ross Racing Forged Pistons
Lowered Compression Ratio
Standard size and spec crank
Standalone Omex 710 series Engine Management, entire engine loom over braided, routed through bulkhead behind heater box
Bosch ‘403’ Grey Injectors
2wd Cosworth Bosch Fuel Pump
3 Bar MAP Sensor
Modified 4x4 Cosworth Throttle body fitted on Modified MFI Inlet Manifold
ALS
ALS Valve
Dizzyless ignition, crank pickup in block
Ford Coil Pack
Ford Motorsport Plugs
Greddy Electronic Boost Controller, “Aeroquiped” vacuum hoses
‘Monster’ K&N Air Filter and Trumpet
GRS Evo 4 Intercooler (brushed finish)
GRS Alloy Radiator
Modified thermostat housing, “Aeroquiped” and powder coated silver
Pro Alloy Turbo Water Cooler Mounted under O/S Wheel arch behind Bumper vent
Pro Alloy Header Tank, Powder Coated Black
Independently Controlled Electronic Twin Fans
Mocal 19 Row Oil Cooler Mounted below air filter on custom made brackets, fully “Aeroquiped” -10 fittings/hose
Adjustable fuel pressure regulator, “Aeroquiped” fuel lines throughout
Baffled Sump
Modified Oil Pick- Up
Ceramic Coated Exhaust Manifold
APT Custom Made T34 Exhaust Down pipe
3” Mongoose Exhaust System with 4” Rolled Out Tail Pipe
Ported & Polished Head, Stainless one piece Larger Valves, Radius Valve Seats
Matched Ported Inlet and Exhaust Manifolds
APT Custom spec Cam
Double Valve Springs
Solid Lifters
Piper Vernier Pulley Wheel
Garret T3/04 Hybrid Turbo Charger
.63 Exhaust Housing
247 ALS Maram Shaft
-34 Garret Actuator
harvey is more interested in cossie engines he dont like building rst with big power he says there more trouble then there worth . but he builds awesome reliable cossie engines
had two of his cossie engine and not a problem with either
if i was to get another rst karl would definatly get my custom he is a top tuner
karl is excellent. gives good advice as well.
the reason he's stoppped working on rst's so much is cos he is fed up of people turning up with old smokers and then moaning when it blows up on the way home
if your car is up to scratch he will work on it.
Engine;
1600cc 8v CVH
3 Bar MAP Sensor
ALS
ALS Valve
Ford Coil Pack
GRS Alloy Radiator
Baffled Sump
APT Custom spec Cam
Solid Lifters
.63 Exhaust Housing
247 ALS Maram Shaft
-34 Garret Actuator
Is That All Tony lol
karl done a sterling job mapping mine and i fixed a few things that he was'nt happy with
, now running closed loop lamba and water injection on a s8 ecu karl will work on any car aslong as its not a piece of shite. but now my helix six paddle clutch is bloody slipping
so the bromster is goner sort me out a twin plate paddle anything that can handle over 400fbt
